Why does configuration state shows as UNK in MD which is running 8.0 code?
MVP
MVP
Q:
A:
When the new MD comes up it will be in unknown state (UNK) so it will not get config from MM.
We have to create a config node and point the device to that node to get the config from MM.
The device will reboot and come up as “update successful” state.
Version history
Revision #:
2 of 2
Last update:
‎03-27-2017 06:40 AM
Updated by:
Labels (1)
Contributors
