Why does my 7200 controller not have network connectivity after loading configuration from an old non-7200 controller?
Environment  : This article applies to 7200 series controllers and AOS version or higher.
Even after restoring the configuration from the old controller to a 7200 series controller, it does not have connectivity to the rest of the network.
The port numbering scheme in a 7200 series controller is different from the scheme used in old controllers. The 7200 uses slot/module/port instead. All other previous controller platforms (800, 2400, 3000 series, 600 series, 5000 and 6000 series) use a slot/port numbering scheme.
In order to get the network connectivity back, you would need to remove the existing port-to-vlan mapping if any in the restored configuration and map correct VLANs to correct ports again with proper port numbering schemes from the new controller's WebUI or CLI.
Version history
Revision #:
1 of 1
Last update:
‎07-18-2014 12:30 PM
Updated by:
Labels (1)
