Why does my session ACL not take effect when I apply it to an egress port?
Product and Software: This article applies to all ArubaOS versions.
In the field, some people are trying to apply a session access list to an outgoing physical port. For example, they want to source nat all the traffic from one subnet to internet via this session ACL, but the result is that this session ACL does not take effect.
Session ACLs work only on ingress traffic on a port; they do not work on egress ports.
Version history
Revision #:
1 of 1
Last update:
‎07-06-2014 10:51 PM
Updated by:
Labels (1)
