Why does the RAP fail to downgrade from ArubaOS 5.0.2.0 to 3.3.2.18 RN code?
Question:  Why does the RAP fail to downgrade from ArubaOS 5.0.2.0 to 3.3.2.18 RN code?
Product and Software: This article applies to RAPs that are downgrading from ArubaOS 5.0.2.0 to 3.3.2.18 RN code.
Problem
ArubaOS 5.0.2 and 3.3.2.18 RN use a different UDP port for PAPI. UDP 8209 is used in ArubaOS 5.0.2.0, and UDP 8211 is used in 3.3.2.18 RN code.
When the controller is downgraded from 5.0.2.0 to 3.3.2.18 RN code, the RAPs that run 5.0.2.0 code continuously send packets to UDP 8209. The 3.3 controller replies with ICMP destination unreachable, then all the RAPs fail to come up.
Solution
The solution is to destination NAT UDP 8209 traffic to UDP 8211, and the RAPs will downgrade eventually.
For example, the RAP role is "authenticated" in the local-userdb:
ip access-list session dst-nat-udp-8209-to-8211
any any udp 8209 dst-nat 8211
user-role authenticated
session-acl dst-nat-udp-8209-to-8211
session-acl allowall
ipv6 session-acl v6-allowall
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 03:12 PM
Labels (1)
Contributors
