Why does the multicast streaming does not work on certain port numbers?
Different ALGs on the controller are reserved for different port numbers. The ALG expects data packets on specific reserved port number in a certain format that is specific for the protocol. For example, port number udp 5000 is used by noe ALG and udp 5002 is used by vocera ALG. Any data packets with these destination port numbers are expected to be in the format specified for the given protocol (eg. noe or vocera).
Below are the list port numbers on which the controller ALG listens.
(Master-7210) #show netservice
Name                  Protocol  Ports       ALG       Type
svc-dhcp              udp       67-68       dhcp
svc-tftp              udp       69          tftp
svc-papi              udp       8211        papi
svc-sccp              tcp       2000        sccp
svc-noe-oxo           udp       5000        noe
svc-vocera            udp       5002        vocera
svc-sec-papi          udp       8209        sec-papi
svc-rtsp              tcp       554         rtsp
svc-svp               119       0           svp
svc-dns               udp       53          dns
svc-sips              tcp       5061        sips
svc-noe               udp       32512       noe
svc-ftp               tcp       21          ftp
If a video multicast stream is sent on one of these port numbers, the controller may drop the packet and the user may not receive the stream since these data packets are not in the format defined for the given ALG protocol. To achieve successful multicast video streaming, we must either disable the respective ALG on the firewall or change the destination port number of the multicast streaming. For example, if the multicast streaming fails on port number udp 5000 (port number used by noe protocol), we can either change the destination port number to a different one or disable the "Stateful VOCERA Processing" on the controller firewall.
The below stateful processings (ALG) can be disabled on the controller firewall.
(Master-7210) #show firewall | include Stateful
Stateful SIP Processing                      Enabled
Stateful H.323 Processing                    Enabled
Stateful SCCP Processing                     Enabled
Stateful VOCERA Processing                   Enabled
Stateful UA Processing                       Enabled
Stateful SIPS Processing                     Enabled
Stateful ICMP Processing                     Disabled
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 12:02 PM
Updated by:
Labels (1)
