Why is IGMP snooping not enabled by default in the Aruba controller?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
IGMP snooping is not enabled by default because it only works when there is a multicast router in the station subnets sending IGMP queries, and IP multicast routing is not that common.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 08:48 AM
Updated by:
Labels (1)
Contributors
