Why is IP mobility not working after an upgrade from ArubaOS 2.5.4?
Product and Software: This article applies to all Aruba controllers and Aruba OS 3.3.1.
IP mobility in ArubaOS 3.1 and later required the user to create the Home Agent Table (HAT). This configuration is not required in ArubaOS 2.5.
The HAT table contains the home agent subnets, VLAN ID, and the home agent switch IP address.
The HAT table and mobility domain configuration are global configuration and if you have a master local setup, configure the HAT table and mobility domain on the master controller and save the configuration.
You do not need to create any mobility domain if you plan to use the default domain. In the master and local controller setup and using the custom mobility domains, you must activate the mobility domain on each controller.
Configuration
Example 1: IP mobility is disabled by default. To enable the IP mobility, use the following CLI or WebUI configurations.
CLI:
(STU2) config
(STU2) (config) #router mobile
(STU2) (config) #end
(STU2) #write mem
WebUI:
1)  Navigate to Configuration > IP mobility.
2)  Check the Enable IP Mobility option and click Apply.
4)  Click Save Configuration.
Example 2: To add a mobility domain, use the following CLI or WebUI configurations.
CLI:
(STU2) #configure t
(STU2) (config) #ip mobile domain my33
(STU2) (mobility-domain) #end
(STU2) #write mem
Web UI:
2)  In Mobility Domain Name, enter the domain name.
3)  Click Add.
Example 3: To activate the domain and create the HAT table entries, use the following CLI or WebUI configurations.
CLI:
(STU2) #configure t
(STU2) (config) #ip mobile active-domain my33
(STU2) (mobility-domain) #hat 128.1.1.0 255.255.255.0 451 10.168.109.71
(STU2) #write mem
Web UI:
2)  In the Domain List, click the mobility domain.
3)  Check the "active" option to activate the mobility domain.
4)  Click Add.
5)  Enter the subnet, netmask, VLAN ID, and Home Agent IP address. Switch IP is recommended.
6)  Click Add.
7)  Click Save Configuration.
To verify your configuration, issue the following commands:
show ip mobile hat
show ip mobile active-domain
Example
(STU2) #show ip mobile hat
Active Home Agent Table (HAT)
Home Agent Table, 3 subnet(s)
subnet mask VlanId Home Agent
10.168.109.64 255.255.255.192 451 10.168.109.71
21.168.109.0 255.255.255.0 551 10.168.109.71
(STU2) #show ip mobile active-domains
Active Mobility Domain(s) Total: 3
Domain name Status
default
my31
my33
(STU2) #
Version history
Revision #:
1 of 1
Last update:
‎07-09-2014 04:09 PM
Updated by:
Labels (1)
Contributors
