Wireless Clients connecting to captive-portal SSID are unable to get an IP after quick reconnection
Question : Why are wireless clients connected to a captive portal SSID not getting an IP if they disconnect and re-connect in quick succession?
Environment Information : Any Aruba OS
Any Aruba AP
Any Aruba Controller
Symptoms : Working wireless clients unable to get an IP if they disconnect and reconnect to wireless.  If we clear the user entry using "aaa user delete mac <user-mac>", the user will be able to connect and get an IP address fine.
Cause :
We keep the L3 entry (user-table) of the user until the expiry of the timer "User Idle-Timeout".  This is 5 minutes by default.  Hence if an authenticated captive-portal user disconnects from wireless and quickly reconnects within 5 minutes (say) then the user is punted to the post-auth role on the Controller.  If post-auth role is restrictive enough then we can potentially block DHCP and hence prevent user from getting an IP address.
Resolution :
If a captive portal authenticated user disconnects from the wireless and reconnects within the "user idle-timeout" period (default 5 minutes), then the will be pushed directly to post-authentication role on the Controller.  However the user will still need to either renew its IP address or get a new IP address from DHCP.  This user attempt to acquire a new IP or renew its IP address, will fail if DHCP is blocked in the post-authenticated role.  Hence we can resolve this issue by allowing DHCP on the post-authenticated role.
Answer :
For the duration of idle-user timeout (default is 5mins), we remember the user IP (L3) entry for authenticated users on the Controller.  This is especially useful for captive portal authenticated users that re-connect to the wireless within  a short time so that they do not need to re-authenticated at the captive portal page again. If an authenticated user disconnects from wireless and reconnects within the configured "user idle-timeout" then we will pushed the user directly to post-authentication role.
Now, since the user disconnected from wireless and re-connected, it will try to do a “DHCP DISCOVER”.  We hence need to allow “DHCP” on the post-authenticated role to allow user to get an IP address this time.
For Example:
Consider a user in post-authenticated role "webaccess".
Configuration before change:
(Aruba) #show rights webaccess
Derived Role = 'webaccess'
Up BW:No Limit  Down BW:No Limit
 L2TP Pool = default-l2tp-pool
PPTP Pool = default-pptp-pool
Periodic reauthentication: Disabled
ACL Number = 78/0
Max Sessions = 65535
access-list List
Position  Name    Type     Location
1         WebAcc  session
WebAcc
Priority  Source  Destination              Service        Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
1         user    any                      udp 68         deny                             Low                                                           4<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<NO ACL ALLOWING DHCP
2         user    any                      svc-dns        permit                           Low                                                           4
3         any     any                      tcp 26000      permit                           Low                                                           4
4         any     any                      svc-ssh        permit                           Low                                                           4
5         user    any                      svc-https      permit                           Low                                                           4
6         user    any                      svc-http       permit                           Low                                                           4
7         user    any                      tcp 8080       permit                           Low                                                           4
8         user    127.108.0.0 255.255.0.0  tcp 9100       permit                           Low                                                           4
9         user    any                      tcp 7777       permit                           Low                                                           4
10        user    any                      svc-ftp        permit                           Low                                                           4
11        user    127.108.2.46             any            permit                           Low                                                           4
Expired Policies (due to time constraints) = 0
Configuration Change:
(Aruba)# config term
(Aruba) (config)# ip access-list session WebAcc
(Aruba) (config-sess-WebAcc)# any any svc-dhcp permit position 2
(Aruba) (config-sess-WebAcc)# write mem
Configuration After Change:
(Aruba) (config-role) #show rights webaccess
ACL Number = 77/0
access-list List
1         WebAcc  session
WebAcc
2         any     any       svc-dhcp permit        Low        4   <<<<<<<<<<<<<<<<<<<<<<<<<<ACL PERMITS DHCP                                             3         user    any                      svc-dns        permit                           Low                                                           4
4         any     any                      tcp 26000      permit                           Low                                                           4
5         any     any                      svc-ssh        permit                           Low                                                           4
6         user    any                      svc-https      permit                           Low                                                           4
7         user    any                      svc-http       permit                           Low                                                           4
8         user    any                      tcp 8080       permit                           Low                                                           4
9         user    127.108.0.0 255.255.0.0  tcp 9100       permit                           Low                                                           4
10         user    any                      tcp 7777       permit                           Low                                                           4
11        user    any                      svc-ftp        permit                           Low                                                           4
Note: Please note that the issue of users not getting an IP after reconnection to wireless might be exacerbated in cases where the user idle-timeout is a higher than the default value.
Version history
Revision #:
1 of 1
Last update:
‎07-14-2014 06:28 AM
Updated by:
Labels (1)
Contributors
Comments
KenP
Hi We have 7220 Wireless controller and 697AP's, Users keeps re-authenticating after a sort of time. I actually tried configuring AAA profile User-Idle timeout to 15300 secs and even the global settings but users experiencing a disconnection reportedly even playing games and active for 30 minutes.
Any suggestions on this?
Best Regards,
Kenneth Penafuerte
Phil-Data Business Systems Inc.
