https://na2.salesforce.com/knowledge/publishing/articleOnlineDetail.apexp?id=kA240000000L3fL
Environment : Aruba OS
Answer :
Mac Acl does not get pushed from master to standby it’s by design.You need to create the Acl on the standby aswell.
HERS IS THE LAB TEST RESULTS
Reproduction Steps:
1) Create a ‘ip access-list mac’ acl in the Master.
2) Did write memory
3) It is not being pushed to the Standby
4) Created a ‘ip access-list session’ acl in the master and that gets pushed to the standby
In Master:
(Aruba3400) #show switches
All Switches
IP Address      Name       Location          Type     Model      Version        Status  Configuration State  Config Sync Time (sec)  Config ID
10.168.172.4    Aruba3400  Building1.floor1  master   Aruba3400  6.2.1.3_39155  up      UPDATE SUCCESSFUL    0                       3
10.168.172.100  Aruba3400  Building1.floor1  standby  Aruba3400  6.2.1.3_39155  up      UPDATE SUCCESSFUL    17                      3
(Aruba3400) (config) #ip access-list mac  TACTest ?
<cr>
(Aruba3400) (config-mac-TACTest)#?
deny                    Specify packets to reject
no                      Delete Command
permit                  Specify packets to forward
(Aruba3400) (config-mac-TACTest)#permit 00:11:22:33:44:55
(Aruba3400) (config-mac-TACTest)#write m
Saving Configuration...
Configuration Saved.
(Aruba3400) (config-mac-TACTest)#show ip access-list mac    a  TACTest
  permit host 00:11:22:33:44:55
In Standby:
All Switches
10.168.172.100  Aruba3400  Building1.floor1  standby  Aruba3400  6.2.1.3_39155  up      UPDATE SUCCESSFUL    0                       4
(Aruba3400) #show ip access-list TACTest
Unknown access-list 'TACTest'
In Master:
(Aruba3400) (config-mac-TACTest)#ip access-list session TACTest2
(Aruba3400) (config-sess-TACTest2)#any any any permit
(Aruba3400) (config-sess-TACTest2)#write m
In Standby:
(Aruba3400) #show ip access-list TACTest2
TACTest2
Priority  Source  Destination  Service  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
1         any     any          any      permit                           Low                                                           4
Version history
Revision #:
1 of 1
Last update:
‎09-19-2014 05:31 AM
Updated by:
Labels (1)
Contributors
