Can E0 port be disabled/shut in IAP?
Environment : In a scenario with 3g/4g as uplink, for various reason the Ethernet ports needs to be shut. Any code above 3.1
From the Access Point list in the GUI, select the AP
Click on Edit
Click on "Uplink" tab and select Enabled for "Eth0 bridging"  (as shown below)
To block  port  E0.
Log into Instant WebUI .
Click on "Wired" from the Main menu in the top-right corner.
Click on "New" to create Wired Ethernet Profile:
Under Wired Settings,  we can see an option admin status next to it please press the drop down arrow and select disable.
show port status --> to verify
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 02:19 PM
Updated by:
Labels (1)
Contributors
