Can an IAP cluster be deployed on the downlink of a Mesh point?
Question: Can an IAP cluster be deployed on the downlink of a Mesh point?
Environment         Switch==== IAP Portal ======IAP Point ======IAP cluster 2
This is both possible but has be deployed with caution. This is the design till 3.4.0.2.
The cluster 2 should not be in the same VLAN as that of IAP Mesh point and portal.
If IAP cluster 2 is deployed in the same Native VLAN as point and portal, then the IAPs will keep rebooting with a message as below.
“(00:00:59) Rebooting AP due to uplink ap denied me, from (d8:c7:c8:cb:dc:e8 192.168.111.51)”
So make this work below scenario is recommended.
Switch==== IAP Portal ======IAP Point (1-Native VLAN, 10,15,45,100 -are other allowed VLANs) ====== Switch (Native VLAN 10, 15,45,100 - are other allowed vlans)IAP cluster 2
One more condition is that both IAP cluster 2 and Mesh points should not have the same SSID serviced/ configured.
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 02:54 PM
Labels (1)
Contributors
