Configurable ESSID in WLAN profile for Aruba Instant
MVP
MVP
Q:
How to configure/modify ESSID name in Instant?
A:
In earlier Instant version, SSID name was same as SSID profile name and it wasn't a configurable variable. Instant version 4.2 allows WLAN administrator to change/modify ESSID name as needed with SSID profile name unchanged. By default ESSID name is set as SSID profile name.
CLI Configuration:
IAP (config) # wlan ssid-profile test
IAP (SSID Profile "test") # essid test-psk
Verification:
show network/show clients
IAP# show network
Networks
Profile Name  ESSID     Clients  Type      Band  Authentication Method  Key Management  IP Assignment  Status   Zone  Coding
test          test-psk  1        employee  all   None                   WPA2-AES        Default VLAN   Enabled  -     Default
IAP# show clients
Client List
Name     IP Address   MAC Address        OS  ESSID     Access Point       Channel  Type  Role  IPv6 Address  Signal    Speed (mbps)
root-PC  10.65.84.94  36:13:00:00:00:01      test-psk  94:b4:0f:ca:bc:2e  36+      AN    test  --            38(good)  240(good)
Number of Clients   :1
Web UI Configuration:
Verification:
Version history
Revision #:
2 of 2
Last update:
‎07-31-2015 07:52 AM
Updated by:
Labels (1)
Contributors
