Configuration of per-user/role bandwidth contract on Instant 4.0
From Instant 4.0, we could configure the Bandwidth contact for per role/user based whereas in earlier released bandwidth contracted accounted both for upstream and downstream traffic.
WEBUI
CLI:-
Per-Role Bandwidth configuration:
6c:f3:7f:cc:a5:08 (config) # wlan access-rule bandwidth-contract
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # bandwidth-limit upstream 3000
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # bandwidth-limit downstream 3000
Per-User Bandwidth configuration:
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # bandwidth-limit peruser upstream 3000
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # bandwidth-limit peruser downstream 3000
Removing Bandwidth contract:
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # no bandwidth-limit upstream
6c:f3:7f:cc:a5:08 (Access Rule "bandwidth-contract") # no bandwidth-limit downstream
If the user had per-user bandwidth in earlier releases configured under the SSID, this value will be treated as “downstream bandwidth contract” for the SSID role.
Example:
Wlan 6c:f3:7f:cc:a4:3c (config) # wlan ssid-profile qa-IAP-BWC-s3
6c:f3:7f:cc:a4:3c (SSID Profile “qa-IAP-BWC-s3 ") # per-user-bandwidth-limit 2000
6c:f3:7f:cc:a4:3c (SSID Profile “qa-IAP-BWC-s3 ") # end
6c:f3:7f:cc:a4:3c# show access-rule qa-IAP-BWC-s3
Access Rules
Dest IP  Dest Mask  Dest Match  Protocol (id:sport:eport)  Action  Log  TOS  802.1P  Blacklist  Mirror  DisScan  ClassifyMedia
any      any        match       any                        permit
Vlan Id           :0
ACL Captive Portal:disable
ACL ECP Profile   :default
CALEA             :disable
Bandwidth Limit   :downstream 2000 kbps (peruser) upstream disable
However from Instant 4.0 bw-contract can be configured both upstream and downstream.
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 11:22 AM
Updated by:
Labels (1)
Contributors
