Configure Radius accounting for wired clients
MVP
MVP
Piror to 4.2 IAP doesn’t support  accounting for wired client.
Wired Accounting support Radius accounting for wired client that are connected to IAP. With this feature enabled,  IAP will send Radius accounting packet to accounting server after client pass Radius authentication.  The behavior of wired accounting is same with wireless accounting.
CLI – configuration:
00:0b:86:a0:d9:00 (config) # wired-port-profile test
00:0b:86:a0:d9:00 (wired ap profile test) # radius-accounting                                             ------------------ enable accounting
00:0b:86:a0:d9:00 (wired ap profile test) # radius-interim-accounting-interval  10          ---------------- accounting interval
00:0b:86:a0:d9:00 (wired ap profile test) # end
00:0b:86:a0:d9:003# commit apply
Use separate accounting mode
00:0b:86:a0:d9:00 (wired ap profile test) # radius-accounting                                                            ------ enable accounting
00:0b:86:a0:d9:00 (wired ap profile test) # radius-interim-accounting-interval  10                             ------ accounting interval
00:0b:86:a0:d9:00 (wired ap profile test) # accounting-server acct-server-1                                      ------ configure separate accounting server
00:0b:86:a0:d9:00 (wired ap profile test) # accounting-server acct-server-2                                      ------ configure separate accounting server
Configuration in running-cfg
 switchport-mode trunk
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name test
 speed auto
 duplex auto
 poe
 type employee
 auth-server cppm244
 captive-portal disable
 dot1x
 radius-accounting
Enable wired accounting via UI
Wired Accounting Debug
•show clients status <mac>”, check client accounting status and session-id
•show ap debug auth-trace-buf”,  check accounting record
•security syslog,  check accounting packet detail info
•Packet capture for accounting packet
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 03:58 PM
Updated by:
Labels (1)
Contributors
