Controller-less WLANs
last person joined: one year ago
Articles relating to existing and legacy HPE Aruba Networking products and solutions including IAP, Central / HPE Aruba Networking Central, MSR, and Outdoor Mesh
DHCP Enforcement on IAP
Mar 08, 2016 04:16 PM
How to block traffic for IAP clients that do not obtain IP address from DHCP
(This article is applicable only for IAP's running on 6.4.3.4-4.2.1.0 code & later)
Enable "enforce-dhcp" parameter in the SSID  --> This would ensure that the traffic for IAP clients that do not obtain IP address from DHCP is blocked. The device may get connected and show up under "show clients". However, the user will not be able to even ping its gateway.
WebUI
Edit the SSID--> Goto Security --> Enable "enforce dhcp" --> Click on Next and Finish
CLI
18:64:72:c9:c4:9c (config) # wlan ssid-profile <ssid-name>
18:64:72:c9:c4:9c (SSID Profile "<ssid-name") # enforce-dhcp
18:64:72:c9:c4:9c# commit apply
Check the running-config for the specific SSID
wlan ssid-profile <ssid-profile>
 enable
 index 3
 type employee
 essid test
 opmode opensystem
 max-authentication-failures 0
 rf-band all
 captive-portal disable
 dtim-period 1
 broadcast-filter none
 enforce-dhcp
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
