Difference between upgrade-image and upgrade-image2 commands in Instant AP
MVP
MVP
Q:
What is the difference between upgrade-image and upgrade-image2 commands in Instant AP's?
A:
Both the commands are used to upgrade the image in Instant AP.
1. Upgrade-image command only allows a single URL.
2. Upgrade-image2 command allows multiple URLs, one for each AP class in the cluster
Other than this difference, both upgrade commands manage partitions the same way which is automatic.
Instant# upgrade-image <url>     ftp/tftp/http URL syntax
Version history
Revision #:
2 of 2
Last update:
‎05-20-2016 10:27 AM
Updated by:
Labels (1)
Contributors
