Disable/Enable USB port on IAP
Q:
How do i disable/enable USB port on an IAP?
A:
Prior to Instant version 4.2, USB function is enable by default and we cannot modify; starting fom IAP 4.2 we have a command were we can modify it if we need to enable/disable the USB port.
CLI configuration:
IAP# usb-port-disable
Note: Command takes effect after AP reboot.
IAP# no usb-port-disable
IAP# show ap-env
Antenna Type:Internal
usb-port-disable:1
WebUI configuration:
Per AP setting-->Uplink-->USB port -->Enable/Disable
Note:  The configuration with usb port “usb-port-disable ” or “no usb-port-disable ”  requires reload to the IAP to take effect.
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 02:06 PM
Updated by:
Labels (1)
Contributors
