Disable static channel on IAP
MVP
MVP
Q:
How to disable static channel from IAP command line?
A:
Below are the CLI command by which we can configure a Static Channel and a way to disable it from command line. Use “a-channel 0 0” or “g-channel 0 0” to disable static channel so IAP can switch back to ARM mode.
Configure a static channel
InstantAP# g-channel 11 15
InstantAP# a-channel  40 10
InstantAP# show ap bss-table
Aruba AP BSS Table
bss                ess            port  ip             phy   type  ch/EIRP/max-EIRP  cur-cl  ap name    in-t(s)  tot-t
18:64:72:bb:d2:53  NXT            ?/?   10.29.163.203  a-HT  ap    40/10/22          0       InstantAP  0        3d:5h:7m:58s
18:64:72:bb:d2:42  mac-auth       ?/?   10.29.163.203  g-HT  ap    11/15/25          0       InstantAP  0        3d:5h:7m:58s
Command to disable
InstantAP# g-channel  0 0
InstantAP# a-channel 0 0
Aruba AP BSS Table
18:64:72:bb:d2:53  NXT            ?/?   10.29.163.203  a-HT  ap    56-/22/22         0       InstantAP  0        3d:5h:14m:24s
18:64:72:bb:d2:42  mac-auth       ?/?   10.29.163.203  g-HT  ap    1/25/25           0       InstantAP  0        3d:5h:14m:24s
Version history
Revision #:
2 of 2
Last update:
‎08-08-2016 11:48 AM
Updated by:
Labels (1)
Contributors
