Do we need to enable "validate PMKID" in IAP?
MVP
MVP
Q:
We have a option to enable / disable validate PMKID in dot1x profile in AOS:
(Master) (config) #aaa authentication dot1x default
(Master) (802.1X Authentication Profile "default") #validate-pmkid
It is disabled by default. This is useful for IOS devices which do not support OKC.
Can we configure this in IAP? If yes, what is the default value?
A:
Validate PMKID is always enabled in IAP. Option to change this is NOT available in IAP.
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 12:32 PM
Updated by:
Labels (1)
Contributors
