Do we support IAP manual GRE with Other vendors like cisco
MVP
MVP
Q:
A:
- We do support Manuel Gre with other vendors but only L2 GRE and we do not support L3.
-IAP manual gre supports ONLY "ethernet over GRE" NOT "ip over GRE".
Here is the few command to configure Manuel GRE on IAp
To configure a manual GRE VPN tunnel:
(Instant AP)(config)# gre primary <name>
(Instant AP)(config)# gre type <type>
(Instant AP)(config)# gre per-ap-tunnel
(Instant AP)(config)# end
(Instant AP)# commit apply
Command to view VPN configuration details.
Instant Access Point# show vpn config
Version history
Revision #:
2 of 2
Last update:
‎07-06-2015 05:14 AM
Updated by:
Labels (1)
Contributors
Comments
boris.gaponenko
Hello there.  We still have the same situation with IAP VPN?  Is there other way how to build L3VPN  with other vendors?
