Do we support wildcard cert on IAP for captive portal
Environment : IAP with captive portal config
IAP doesn’t support wildcard for captive portal cert. As of now, the internal captive portals on the IAP only use a fixed, self-signed certificate, and cannot be modified.
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 01:33 PM
Updated by:
Labels (1)
and when will this be supported?
This is supported from Release
Sreeram Sridharan:  there won't be 6.5 for Orion platform?
@ambrozy Please be informed that last supported version for Instant Orion platform is 4.2.x.
Refer : End-of-life Information -
