Does IAP support PPPoE on the uplink port? What are the features supported?
Environment : This article applies to all the Instant APs running OS version 6.1.3.4_3.1.x.x or above.
With 6.1.3.4-3.1.x.x, PPPoE is now a supported uplink type. Here are the currently supported features:
  • PPPoE is in the same level as Ethernet and is only triggered when the AP fails to get IP address.
  • Only single AP deployments are supported with PPPoE uplink.
  • No uplink redundancy when PPPoE is used as uplink.
  • Supports PAP and CHAP.
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 12:29 PM
Updated by:
Labels (1)
Contributors
Comments
Wolf Wang
I need to use PPPoE in multiple IAP deployments. How do I setup?
Can use the basic functions of this home AP?
