Does IAP support accounting for wired client?
MVP
MVP
Q:
A:
Yes; IAP support accounting for wired client as well from IAP code 4.2 and above.
  • Before 4.2
 IAP doesn’t support  accounting for wired client.
  • In 4.2
Wired-Accounting support Radius accounting for wired client. With this feature enabled,  IAP will send Radius accounting packet to accounting server after client pass Radius authentication. The behavior of wired accounting is same with wireless accounting.
Enable accounting in wired-port-profile
00:0b:86:a0:d9:00 (config) # wired-port-profile test
00:0b:86:a0:d9:00 (wired ap profile test) # radius-accounting                                                            ------ enable accounting
00:0b:86:a0:d9:00 (wired ap profile test) # radius-interim-accounting-interval  10                             ------ accounting interval
00:0b:86:a0:d9:00 (wired ap profile test) # end
00:0b:86:a0:d9:003# commit apply
Configuration in running-cfg
 switchport-mode trunk
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name test
 speed auto
 duplex auto
 poe
 type employee
 auth-server cppm244
 captive-portal disable
 dot1x
 radius-accounting
Use separate accounting mode
00:0b:86:a0:d9:00 (wired ap profile test) # accounting-server acct-server-1                                      ------ configure separate accounting server
00:0b:86:a0:d9:00 (wired ap profile test) # accounting-server acct-server-2                                      ------ configure separate accounting server
 allowed-vlan all
 native-vlan guest
 no shutdown
 speed auto
 duplex auto
 poe
 type employee
 auth-server cppm244
 dot1x
 radius-accounting
Enable wired accounting via UI
“show clients status <mac>”, check client accounting status and session-id
  • show ap debug auth-trace-buf”,  check accounting record
  • security syslog,  check accounting packet detail info
packet-capture
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 01:42 PM
Updated by:
Labels (1)
Contributors
