Does IAP support configuring different ARM power ranges for the a-radio and g-radio bands?
Q:
A:
For controller based APs (ArubaOS), we can map separate ARM profiles and configure different tx-power ranges for the a-radio and g-radio.
However, IAP didn't support configuring different ARM power ranges for differnt bands until 6.4.3.1-4.2.0.0 where the same ARM power range was applied to both radios.
In Instant 6.4.3.1-4.2.0.0, the Customize ARM power range option is added to the radio profile configuration window to allow administrators to set transmit power limits for a specific radio band.
Instant ARM in Pre 4.2
Instant ARM 4.2 and above
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 12:09 PM
Updated by:
Labels (1)
Contributors
