Does IAP support wildcard certificate for captive portal authentication?
MVP
MVP
Q:
A:
IAP doesn't support wildcard server certificate for captive portal until Instant version 4.3.
Starting from Instant 6.5.0.0-4.3.0.0, IAP supports wildcard server certificate for captive portal authentication.
When a wildcard SSL certificate (with CN as *.domainname.com) is installed on the IAP for captive portal authentication, IAP uses the URL as "captiveportal-login.domainname.com" to present the captive portal page.
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 12:03 PM
Updated by:
Labels (1)
Contributors
