Does local login to Instant cluster works, when management authentication is configured and active?
Environment         This article applies to Aruba Instant Access Points.
In enterprise deployments, general practice is to allow management access to networking devices where the credentials get authenticated against the Active Directory Server or any other database. When this is configured in Instant deployment, then the ability to login locally with "admin" credentials gets restricted.
Note:      Fallback  indicates that when the connection to authentication server is failed/down, the ability to login locally gets enabled.
Version history
Revision #:
1 of 1
Last update:
‎11-13-2014 04:53 PM
Updated by:
Labels (1)
Contributors
