Does the automatic upgrade works for IAP's running on Early deployment release?
MVP
MVP
Q:
A:
The automatic upgrade option will only show a newer firmware version (if present) if IAP's are running on General Availability (GA) release.
The new version that will be listed will be a GA release as well.
In case , IAP is running on Early deployment (EA) release, automatic upgrade option will not yield any results.
Version history
Revision #:
2 of 2
Last update:
‎05-20-2016 11:03 AM
Updated by:
Labels (1)
Contributors
