Enabling "preferred master" on Instant AP (IAP) does not work if "Instant" is broadcast.
MVP
MVP
Problem:
  WLAN administrator can enforce a particular Instant AP to act as a Master.
Starting from InstantOS version 6.3.1.1-4.0.0.0  we can selectively choose one of the member in the cluster and set it as "Preferred Master".
Provisioning of IAP as a master can be done by using the Instant UI or CLI.
But enabling this option in a specific AP will not take effect if factory default SSID "Instant" is still being broadcasted.
Diagnostics:
Example:
Two APs in cluster (AP1 & AP2) with AP1 initially acting as master. Factory-default SSID "Instant" is seen broadcasted.
Set "preferred master" to enable for AP-2 and then reboot the specific AP for the changes to take effect.
Once the AP reboots and comes up you could see the AP being set to "Init ---> slave" during the boot process and the AP-2 continues to act as slave irrespective of preferred master being set.
To verify that the config is present please execute #show ap-env on AP-2
AP2# show ap-env
Antenna Type:Internal
wifi0_arm_channel:52
wifi0_arm_power:3
wifi1_arm_channel:6
wifi1_arm_power:3
iap_master:1      ---------> this indicates that the preferred master has been set to "enable"
AP2#
Solution
To make the specific AP act as preferred master we have to configure a non-factory default SSID so that the "instant" SSID gets removed.
Now go to AP2 --- 'Edit' and enable "preferred master". Reboot the specific AP for changes to take effect.
AP2 comes up as a master AP and then the AP1 reboot itself and joins the cluster as a slave.
Version history
Revision #:
3 of 3
Last update:
‎05-28-2016 02:15 AM
Updated by:
Labels (1)
Contributors
