Enforcing Firmware Upgrade feature in Aruba Central
How to enable Enforcing Firmware Upgrade feature in Aruba Central?
Starting from Aruba Central 2.3.1, Enforcing Firmware upgrade feature has been introduced.
We need to select the desired group then navigate to Network Management > Maintenance > Firmware menu allows you to check firmware compliance for devices in a group and upgrade these to a specific firmware version. Enforcing firmware upgrade is supported only at the group level.
We need to select settings button on the firmware and choose the firmware that need to enforced for the specific group.
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 11:37 AM
Updated by:
Labels (1)
