Question: How check the subnet of Virtual controller assigned IP address or the DHCP pool of the Magic VLAN?Environment: If client VLAN has been assigned an IP address through Virtual controller, it will be assigned through the Magic VLAN pool in the Virtual controller.
The Magic VLAN DHCP pool on the controller from which clients will be assigned IP address can be verified by the below command.********************************************************************************************************* 9/23/2013 21:53:00 PM Target: Abilash-lab Command: show dhcp-allocation*********************************************************************************************************---------------------/etc/dnsmasq.conf--------------------listen-address=127.0.0.1addn-hosts=/etc/ld_eth_hostsaddn-hosts=/etc/ld_ppp_hostsdhcp-src=172.31.98.1dhcp-leasefile=/tmp/dnsmasq.leasesdhcp-authoritativefilterwin2k#magic-vlan{ vlan-id=3333 dhcp-range=172.31.98.3,172.31.99.254,255.255.254.0,12h dhcp-option=1,255.255.254.0 dhcp-option=3,172.31.98.1 dhcp-option=54,172.31.98.1}---------------------/tmp/dnsmasq.leases------------------946754172 3c:a9:f4:1d:ac:a4 172.31.99.123 3333 BLR-ASOUNDARARAJAN-T430s 01:3c:a9:f4:1d:ac:a4This gives detailed information about the DHCP pool range, VLAN ID and the current DHCP leases. Default lease period is 12 hours.
