How do I change transmit rates on IAP 2.0?
Question:  How do I change transmit rates on IAP 2.0?
Product and Software: This article applies to Instant AP 2.0.
For the client station to associate with an AP successfully, the station must be able to communicate by using the configured basic rates that the AP requires. The transmit rate setting is used to set the fastest rate that an AP or wireless router will send data.
Transmit rates can be configured per SSID and can be manipulated for legacy or non high throughput (HT) clients.
To see these options, click <more in the Basic Info window.
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 02:19 PM
Labels (1)
Contributors
