How do I configure Captive Portal with MAC authentication on an SSID in Aruba Instant?
Product and Software: This article applies to Aruba Instant 3.2
Points to remember:
Clients should pass either MAC-auth or captive portal.
Clients that pass MAC-auth will get MAC-auth-only role.
Clients that fail MAC-auth will be required to do captive portal auth.
Step 1: Click New to create and SSID
Step 2: Select Guest to create Guest Network.
Step 3: Select IP Assignment
Step 4: Choose captive portal, and enable mac authentication.
Step 5: Enable mac-auth-only role, if client pass mac authentication, it will get this role. If this option is disabled, client will get role derivation.
Step 6: You can see the SSID Broadcasting.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 05:20 PM
Updated by:
Labels (1)
Contributors
