How do I configure DHCP option-based role derivation for an Open SSID on Aruba Instant?
Product and Software: This article applies to Aruba Instant 3.2
To configure a DHCP-option rule profile with Open SSID
Step 1: Click New under Name
Step 2: Give SSID Name, Select “Employee” for Primary usage and Hit Next
Step 3: Select IP assignment, VLAN assignment and Hit Next.
Step 4: Select Security Level "Open" and Hit Next
Step 5: Select Access Rules "Role-based" and Click New
Step 6: Select Attribute, Operator, enter String and Select Role, Press OK
Step 7: We can see the configured Rule and Hit Finish
Step 8: We can see the SSID is Broadcasting.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 04:39 PM
Updated by:
Labels (1)
Contributors
