How do I configure and place different IAPs (Virtual controllers) into different groups using Aruba Central WebUI?
This article explains the steps to create different groups on Aruba Central WebUI and place different IAPs (Virtual Controllers) into different groups.
Feature Notes
Using the Aruba Central dashboard, we can create multiple groups and place different IAPs in those groups.
This article applies to all the IAPs running a minimum OS version of and managed by Aruba Central.
Configuration Steps:
To create a new group and to add a virtual controller to the group:
  1. Click on the drop down on the top left. This displays a list of all the existing groups. If you click on the icon on the left of the group, it will show all the VCs in that group.
       2. Click on Add at the bottom.
       3.  Enter the group name and select the VCs from the list that are supposed to be a part of that group. Click Save.
After you have completed the configuration, you would see the selected VCs are displayed under the new group:
Version history
Revision #:
1 of 1
Last update:
‎06-18-2014 02:34 PM
Updated by:
Labels (1)
