How do I disable 802.11a SSID on my dual-band IAP?
Question: How do I disable 802.11a SSID on my dual-band IAP?
Product and Software: This article applies to Aruba Instant 6.1.3.4_3.1.0.0.
Dual-band IAPs such as IAP-105 broadcast the SSID in the 2.4 GHz and 5.0 GHz bands by default.
To disabled the 802.11a (5 GHz) band SSID, follow these steps:
1) Click the SSID name.
2) Click Edit.
3) Click Show advanced options.
4) On the Band, select 2.4 GHz and click Next.
5) Continue to click Next and Finish to complete the change.
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 09:23 PM
Labels (1)
Contributors
