How do I quickly search a specific Instant AP or Mobility Access Switch on Aruba Central?
MVP
MVP
Q:
A:
Central provides a standard web-based interface that allows you to configure and monitor Instant Access Points (IAPs) and Mobility Access Switches.  Integrated in this web interface is a Search tex box, which can be used by an administrator to search for an IAP, Mobility Access Switch, client, notification event, network or labels.
When you type a search string, the search function suggests matching keywords and allows you to automatically complete the search string entry. This option proves very handy when a user is not aware in which ap group, a client or IAP is part of.
Version history
Revision #:
2 of 2
Last update:
‎08-04-2015 05:53 PM
Updated by:
Labels (1)
Contributors
