How do I switch between Aruba Central accounts without having to re-login?
MVP
MVP
Q:
A:
An user can be part of multiple Aruba Central accounts. Typically in managed service provider scenarios, where one provider would manages multiple central customers, anything that can help switching accounts without need to re-login is a much handy and hassle free.
Keeping such requirements in view, Aruba Central has come up with a feature called "Switch Customer". As shown below:
When "Switch Customer" is selected, you are presented with a page that shows up the associated accounts.
You can click on the any account that you would like to be logged into...
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:00 PM
Updated by:
Labels (1)
Contributors
