How do we disable an SSID on Aruba Instant APs?
This article explains the steps to enable/disable an SSID on IAPs. This is a new feature added in IAP OS version Prior to this code, we did not had any option of disabling the SSID. We could only delete or hide the SSID.
This article applies to all the IAPs running a minimum OS version of
Environment : All the sample outputs and screenshots in this article are tested on IAP 135 running on
1. Create a new SSID
2. Click on "show advance option".
3.Check/Uncheck "Disable SSID" option.
To Verify:
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 04:57 PM
Updated by:
Labels (1)
