How does L3 Mobility work in Instant AP?
MVP
MVP
This article applies to Instant APs starting from version 6.2.1.0 - 3.3.0.0.
This kind of design in an Instant AP deployment is to make wireless client roam seamlessly across clusters on the same SSID.
If the IP address changes when a client roams, from one AP to the other AP, where SSID name is identical, it loses connectivity to the existing session that it has established and all TCP based sessions have to be restarted. So to avoid this, the aim of this wireless roaming system is to let the client retain its IP address upon a roam.
This scenario needs configuration, where cluster B is informed about IP addressing on cluster A and which subnets are present on cluster A.
Notice that VLAN 10 is not present on cluster B. If a client roams, to it, based on DHCP requests the client sends on vlan 10, it determines, that it belongs to cluster A and creates a GRE tunnel to cluster A.
  • Client VLAN should not be sent across trunk port. It should be specific to each cluster.
  • APs VLAN in each cluster should be sent across trunk so that they get to know about each other when the L3 mobility is configured.
  • Client connecting to cluster A would get IP address from vlan 10.
  • When it roams to cluster B it remains its IP address and now you could see the GRE getting formed between two clusters in the #show datapath session output.
  • All other outputs with respect to L3 mobility can be verified here.
It is recommended that you configure all client subnets in the mobility domain. When client subnets are configured:
 If a client is from a local subnet, it is identified as a local client. When a local client starts using the IP address,
the L3 roaming is terminated.
If the client is from a foreign subnet, it is identified as a foreign client. When a foreign client starts using the
IP address, the L3 roaming is set up.
Please refer to the above sample topology
Configuration from both the APs.
AP1:
AP1# show l3-mobility config
Flags
Type                       Value
Home Agent Load Balancing  disable
Virtual Controller Table
Virtual Controller IP
172.16.0.100      ------------   IP address of two Virtual controllers.
172.16.2.250
Subnet Table
Subnet       Netmask        VLAN  Virtual Controller
172.16.10.0  255.255.255.0  10    172.16.0.100          ------------------------------------ Two client subnets. 172.16.x.x is the client subnet on AP1 and 10.241.x.x is the client subnet that exist on AP2.
10.241.11.0  255.255.255.0  11    172.16.2.250
AP2:
AP2# show l3-mobility config
Flags
Type                       Value
172.16.2.250
172.16.0.100
Subnet Table
Switch 1 where AP1 is connected:
show ip interface br
Flags: S - Secondary IP address
Interface                   IP Address / IP Netmask        Admin   Protocol   Flags
vlan 1                    172.16.0.250 / 255.255.255.0     Up      Up
vlan 10                    172.16.10.2 / 255.255.255.0     Up      Up
vlan 11                    10.241.11.1 / 255.255.255.0     Up      Down
vlan 169                  10.20.25.254 / 255.255.255.0     Up      Down
vlan 2                      172.16.2.2 / 255.255.255.0     Up      Up
vlan 4094                172.16.94.254 / 255.255.255.0     Up      Down
vlan 99                  172.16.98.254 / 255.255.255.0     Up      Down
(ArubaS1500-12P) #show trunk
Trunk Port Table
Port     Vlans Allowed  Vlans Active  Native Vlan
GE0/0/0  1-2            1-2           1     ---------  only AP vlans are allowed across trunk so that each cluster knows information about other cluster.
GE0/0/5  1,10           1,10          1
Switch 2 where AP2 is connected:
Probe: U - Up, D - Down, U/O - Up & Own IP, N/A - Not Applicable
Interface                   IP Address / IP Netmask        Admin   Protocol Probe  Flags
vlan 1                    172.16.0.150 / 255.255.255.0     Up      Up       N/A
vlan 10                    172.16.10.1 / 255.255.255.0     Up      Down     N/A
vlan 100                    10.100.0.1 / 255.255.255.0     Up      Down       N/A
vlan 11                    10.241.11.2 / 255.255.255.0     Up      Up     N/A
vlan 2                      172.16.2.1 / 255.255.255.0     Up      Up       N/A
Trunk Port Table
GE0/0/0  1-2            1-2           1
GE0/0/5  2,100          2,100         2
Steps to reproduce:
  1. When client connects to AP1 in “l3-mobility” SSID it gets IP address from vlan 10. Please note that the GRE tunnel is not formed as the client did not roam to the other cluster yet.
  2. Client roams from AP1 to AP2. Now AP2 identifies that the client subnet is not local to it and since L3 Mobility is configured it will look for the same subnet in the “subnet table” configured under L3 mobility.
  3. Since subnet is present, AP2 identifies that this client has roam from a different cluster. As the client wants to retain its IP address and does layer 3 communication using the same IP address, AP2 forms a GRE tunnel with the AP1. So the client would continue to pass the traffic through GRE tunnel via AP1.
Outputs to verify:
Output from AP1:
AP1# show l3-mobility datapath
L3 Mobility Datapath Home Table
Client Index  Client MAC         Home Vlan  Destinaton Device Index
00            5c:51:88:a7:a6:66  10         8464
L3 Mobility Datapath Foreign Table
Client Index  Client MAC  Home Vlan  VAP Vlan  Destinaton Device Index  HAP IP  Virtual Controller IP  Packets Forwarded
L3 Mobility Datapath Tunnel Table
Tunnel Device  Remote Protocol  Dest IP       Clients  Idle Time  Rx Packets  Tx Packets  Rx Mcasts  Tx Mcasts  ARP Proxy Pkts  Tx Jumbo  MTU   Rx HB  Tx HB  MTU Reqs  MTU Resps  HB Mismatch  IP Mismatch  Type    Vlan Translations
mip000         0x8800           172.16.2.254  1        29         2           4           0          0          0               1         1500  1      2      0         0          0            0            to-FAP  -
AP1# show datapath session | inc 47      --------------------- To verify if GRE is formed
172.16.0.254      172.16.2.254    47   0     0     0    0    0   0   local       26   FC
172.16.2.254      172.16.0.254    47   0     0     0    0    0   0   local       26   F
AP1# show l3-mobility status
Roaming Client Table
Client MAC         Home Vlan  VAP Vlan  Tunnel ID  Status      Virtual Controller IP  Peer IP       Old AP IP  Device Name
5c:51:88:a7:a6:66  10         100       0          home,ready  172.16.2.250           172.16.2.254  0.0.0.0
Tunnel Table
Peer IP       Local Tunnel ID  Remote Tunnel ID  Use Count  Type
172.16.2.254  0                0                 1          to-HAP
Virtual Controller IP  Type  HAP IP  Local Tunnel ID  Remote Tunnel ID
172.16.0.100           C     -       -                -
172.16.2.250           C     -       -                -
Output from AP2:
AP2# show l3-mobility datapath
00            5c:51:88:a7:a6:66  10         100       8464                     172.16.0.254  172.16.0.100           2
mip000         0x8800           172.16.0.254  1        21         2           4           0          0          0               1         1500  1      2      0         0          0            0            to-HAP  (10->100)
AP2# show datapath session | inc 47
172.16.0.254      172.16.2.254    47   0     0     0    0    4   1   local       c6   F
172.16.2.254      172.16.0.254    47   0     0     0    0    0   1   local       c6   FC
AP2# show l3-mobility status
5c:51:88:a7:a6:66  10         100       0          foreign,ready  172.16.0.100           172.16.0.254  172.16.0.254  aruba001
Tunnel Table
172.16.0.254  0                0                 1          to-FAP
172.16.0.100           C     172.16.0.254  0                0
Version history
Revision #:
3 of 3
Last update:
‎05-28-2016 02:09 AM
Updated by:
Labels (1)
Contributors
