- Article History
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Email to a Friend
- Printer Friendly Page
- Alert a Moderator
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
How does failover of AMP (Airwave Management Platform) server work on Aruba Instant APs?
Environment : This article applies to all the IAP running a minimum version of 6.1.3.4-3.1.x.x. Any version prior to this does not have this feature.
This article explains how the IAPs switch between the primary and backup AMP server in case of non-availability of the primary and the backup servers.
An IAP takes around 5 minutes to switch over from the primary Airwave server to the backup server in case the primary server is unreachable. It takes 2 duty cycles (minutes) to Judging the down status of the primary AMP server and another 3 duty cycles (minutes) to connect, identify and log into the backup AMP server.
When using the backup AMP, IAP will continue to attempt a connection to the primary AMP every duty cycle (1 minute). If the attempt becomes successful, IAP will log out of the backup AMP and log into the primary AMP.
