How does new Label Management feature works in Aruba Central?
Central provides a standard web-based interface that allows you to configure and monitor multiple Aruba Wi-Fi networks.
With as many as devices that central could manage, searching a specific device or set of devices becomes difficult. This is where "Label management" feature of Aruba Central helps out.
With "Label Management", administrator can create various labels in advance and use them to assign it to different IAPs or Switches as required. Once the labels are assigned, user can use the label string to search a device or group of devices in central.
Follow these steps create various set of labels in "Label Management":
