How is theTransmit EIRP calculated for IAPs post 6.5.2.x
MVP
MVP
Q:
How is the Transmit EIRP calculated for IAPs post 6.5.2.x?
A:
Article applicable for AP 2xx and 3xx series APs.
On the older version transmit EIRP was calculated = user configured EIRP+Antenna gain
Post 6.5.2.x Transmit EIRP is calculated = user configured EIRP + Antenna gain + MIMO Gain
power gain = 10*log (#txchains) --> ( TX chain is varied across different models of the APs).
Example:
AP 103,207,205,203H203R,205H & 303H - 2 Tx Chains
AP 215,225 - 3 TX Chains
AP 315 - 2 TX chains in 2.4Ghz and 3 TX chains in 5Ghz
AP 325,335 - 4 TX chains
In general, radio will not support per chain conducted power say <0 dBm (1 mW)
Example:
Pre 6.5.2.
If a user configured EIRP is 5 dBm then the transmit EIRP will be displayed as 5 dBm.
However, actual EIRP calculated = 5 dBm-4dBi+10*log(4)+3dBi = 10 dBm
Post 6.5.2.
In post 6.5.2. the AP will display the actual Transmit EIRP which includes the MIMO gain.
Following command will help to check the min transmit EIRP,
# show ap debug power-table. --> can be specified with radio 0 &1 respectively.
Example:
00:0b:86:ed:c5:20# show ap debug power-table
Home Channel:                   36
Channel Width:                  20MHz
User Configured:                6.0 dBm (EIRP) User Input
                                7.2 dBm (EIRP) Effective
                                0.0  dBm (Conducted)
Min Power:                      7.2 dBm (EIRP)
                                0.0  dBm (Conducted)
Max Power:                      22.7 dBm (EIRP)
Actual Power:                   7.2 dBm (EIRP)
Antenna Gain:                   4.3  dB
                                4.25 dB (Rounded to quarter-dB)
Antenna Polarization:           Co-Polarized
Number of Active Chains:        2
Muli-Chains Power Gain:         3.0 dBm
TXBF Max Correlation Gain:      3.0 dBm
Power Limit Under 802.3af:      No
OLPC:                           On
Regulatory Limits (Conducted, dBm):
20MHz:
             Nss Ntx
CCK/DSSS      1   1    *     *     *     *
OFDM          1   1    15.5  15.5  15.5  15.5  15.5  15.5  15.5  15.5
HT/VHT        1   1    15.5  15.5  15.5  15.5  15.5  15.5  15.5  15.5  15.5  15.5
CCK/DSSS      1   2    *     *     *     *
OFDM CDD      1   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5
HT/VHT CDD    1   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5
HT/VHT STBC   1   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5
HT/VHT SDM    2   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5
HT/VHT TXBF   1   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5
HT/VHT TXBF   2   2    12.5  12.5  12.5  12.5  12.5  12.5  12.5  12.5  -0.25 -0.25
Board Limits (Conducted, dBm):
20MHz:
             Nss Ntx
CCK/DSSS      1   1    *      0.0   0.0   0.0
OFDM          1   1    16.0  16.0  16.0  16.0  16.0  15.5  15.0  14.5
HT/VHT        1   1    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  14.0  14.0
CCK/DSSS      1   2     0.0   0.0  *      0.0
OFDM CDD      1   2    16.0  16.0  16.0  16.0  16.0  15.5  15.0  14.5
HT/VHT CDD    1   2    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  14.0  14.0
HT/VHT STBC   1   2    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  14.0  14.0
HT/VHT SDM    2   2    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  14.0  14.0
HT/VHT TXBF   1   2    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  14.0  14.0
HT/VHT TXBF   2   2    16.0  16.0  16.0  16.0  15.5  15.0  14.5  14.0  *     *
Combined Target Powers (Conducted, dBm):
20MHz:
             Nss Ntx
OFDM          1   1     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT        1   1     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
OFDM CDD      1   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT CDD    1   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT STBC   1   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT SDM    2   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT TXBF   1   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
HT/VHT TXBF   2   2     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  *     *
Actual Transmit Powers (EIRP, dBm):
20MHz:
             Nss Ntx
OFDM          1   1     4.25  4.25  4.25  4.25  4.25  4.25  4.25  4.25
HT/VHT        1   1     4.25  4.25  4.25  4.25  4.25  4.25  4.25  4.25  4.25  4.25
OFDM CDD      1   2     7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25
HT/VHT CDD    1   2     7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25
HT/VHT STBC   1   2     7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25
HT/VHT SDM    2   2     7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25
HT/VHT TXBF   1   2    10.25 10.25 10.25 10.25 10.25 10.25 10.25 10.25 10.25 10.25
HT/VHT TXBF   2   2     7.25  7.25  7.25  7.25  7.25  7.25  7.25  7.25 *     *
Note:
  Nss: Number of Spatial Streams
  Ntx: Number of Transmit Chains
  TXBF: Transmit Beamforming
  OLPC: Open Loop Power Control
  Effective User Configured (EIRP) = MAX(User Input (EIRP), Min Power (EIRP))
  User Configured (Conducted) Power is maxed at 31.75 dBm
  Board Limits = the original Board Limits - Transmit Power Back-off
  Combined Target Powers = MIN(Regulatory Limits, Board Limits, User Configured (Conducted),
                               Power Limit Under 802.3af)
  Actual Transmit Powers = Combined Target Powers + Muli-Chains Power Gain + Antenna Gain
                           + TXBF Correlation Gain
Version history
Revision #:
2 of 2
Last update:
‎12-04-2017 12:44 PM
Updated by:
Labels (1)
Contributors
