How to Configure Per-AP SSID and Per-AP-VLAN Settings On a Wireless Profile on IAP
MVP
MVP
Configuring Per-AP SSID and Per-AP-VLAN Settings On a Wireless Profile
Starting from 6.4.4.4-4.2.3.0, we support each IAP to broadcast its own ESSID & its own client VLAN to be configured respectively. We define two variables ‘per_ap_ssid’ and ‘per_ap_vlan’. The two variables can be set in apboot or via CLI command per AP.
Scenario example:
     IAP's in a cluster are located at different classrooms A,B,C. Each classroom needs its own one unique ESSID, “class_A”, “class_B”, “class_C” and isolate broadcast/multicast domain across IAP's with different client vlan.
     In above scenario, in order to avoid exceeding 16 SSID profiles  limitation in configuration, we can use these two per AP variables.
* Configure specifically on each AP which needs to broadcast the unique SSID
             18:64:72:c9:c4:9c# per-ap-ssid test-master
             18:64:72:c9:c4:9c# per-ap-vlan 100
* Configure only on VC, in the SSID-Profile
            18:64:72:c9:c4:9c (SSID Profile "test-ssid") # essid $per-ap-ssid
            18:64:72:c9:c4:9c (SSID Profile "test-ssid") # vlan $per-ap-vlan
            18:64:72:c9:c4:9c (SSID Profile "test-ssid") # exit
            18:64:72:c9:c4:9c (config) # exit
            18:64:72:c9:c4:9c# commit  apply
            committing configuration...
            configuration committed.
            18:64:72:c9:c4:9c#
After configuring, validate the configuration by using the below show command
18:64:72:c9:c4:9c# show  ap-env
 Antenna Type:Internal
 mesh-ldart-disable:1
 per_ap_ssid:test-master
 per_ap_vlan:100
18:64:72:c9:c4:9c#
18:64:72:c9:c4:9c# show running-config | begin ssid-profile
wlan ssid-profile test-ssid
 enable
 index 0
 type employee
 essid $per-ap-ssid
 wpa-passphrase cff89fe6c659f08b14bb03741c58a72dc281775dfb52aa48
 opmode wpa2-psk-aes
 max-authentication-failures 0
 vlan $per-ap-vlan
 rf-band all
 captive-portal disable
 dtim-period 1
 broadcast-filter none
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
18:64:72:c9:c4:9c# show  network
Networks
Profile Name    ESSID         Clients     Type      Band  Authentication Method  Key Management  IP Assignment       Status    Zone  Coding   Active
18:64:72:c9:c4:9c# show  ap bss-table
Aruba AP BSS Table
bss                ess          port  ip             phy   type  ch/EIRP/max-EIRP  cur-cl  ap name            in-t(s)  tot-t
18:64:72:1c:49:d0  test-master  ?/?   10.17.170.248  a     ap    64/9/22           0       18:64:72:c9:c4:9c  0        24s
18:64:72:1c:49:c0  test-master  ?/?   10.17.170.248  g-HT  ap    11/15/21          0       18:64:72:c9:c4:9c  0        23s
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:2
Num Associations:0
18:64:72:c9:c4:9c#
test-ssid     $per-ap-ssid     0        employee     all   None                   WPA2-AES        VLAN $per-ap-vlan  Enabled    -     Default  Yes
18:64:72:c9:c4:9c#
18:64:72:c9:c4:9c#
Aruba AP BSS Table
Num APs:2
Num Associations:0
18:64:72:c9:c4:9c#
Version history
Revision #:
2 of 2
Last update:
‎05-20-2016 10:56 AM
Updated by:
Labels (1)
Contributors
