How to check Aruba Central connectivity from IAP command line?
MVP
MVP
Q:
A:
Starting from  Aruba Instant release 4.2, more information is made available regarding the connection status of IAP cluster with Aruba Central.  Central Uptime, Central Status, and Central Login Status are the parameters which would be helpful to understand the connectivity duration.
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 01:33 PM
Updated by:
Contributors
Comments
martinpoulin
Is there a command to force a config download from the cloud?
i.e. if "show ap debug cloud-server" shows "cloud-config-received: FALSE", what can we do?
Hi Martin,
Please let me know the number of IAP's in the cluster.
Please provide the following outputs:
show activate status
show log provision
show version
show log ap-debug | include awc
If you reboot the master IAP, does the cluster downloads the configuration
