How to check if IAP's are sending RTLS tags
Question: What is the command to check if IAP's are sending RTLS tags to the server?
Environment: This applies to all IAP models and versions.
Instant supports the configuration on RTLS as shown below:
(Snip from IAP-105 running 4.1.0.0):
Once configured, how do we check if the IAP's are sending the RTLS tag information to the respective server.
For this, we can make use of the below command as in initial troubleshooting step in issues related to RTLS:
With the help of the above command we can see the number of Tags Sent from the IAP to the respective servers. This command needs to be run on individual IAP's.
Version history
Revision #:
1 of 1
Last update:
‎11-17-2014 06:36 AM
Labels (1)
Contributors
