How to check in IAP packets policied and dropped because of Bandwidth Contract?
Introduction : How to check in IAP packets policied and dropped because of Bandwidth Contract?
Feature Notes : This article written based on version  6.4.0.3-4.1.0.1.
Environment : SSID having Bandwidth contract configured.
Network Topology : IAP ====SSID (with bandwidth contract)  )))) client
Answer : Can use the below command to check policed and dropped packets with bandwidth contract.
18:64:72:c8:20:16# get-sysctl role_bwm_table
Received BWM Config:
ACL  DIR  Contract-ID PerUser UseCount Rate
Allocated Contracts:
Contract-ID Rate       UseCount Available-Bytes Max-Bytes Policed-Bytes Queued-Bytes Queued-Pkts Dropped-pkts
1           10240000   1        320000          320000    0              0              0              0
2           1024000    1        32000           32000     0              0              0              0
3           10240000   1        320000          320000    0              0              0              0
4           1024000    1        32000           32000     0              0              0              0
5           10240000   1        320000          320000    0              0              0              0
6           1024000    1        32000           32000     0              0              0              0
7           10240000   1        320000          320000    0              0              0              0
8           1024000    1        32000           32000     0              0              0              0
Bandwidth Contracts for cpu type 0 has 9 contracts
BWM divisor for type:0 : 4(4)
  1(cpu:0): flags: 0x0, 10240000 bps, name:
  2(cpu:0): flags: 0x0, 1024000 bps, name:
  3(cpu:0): flags: 0x0, 10240000 bps, name:
  4(cpu:0): flags: 0x0, 1024000 bps, name:
  5(cpu:0): flags: 0x0, 10240000 bps, name:
  6(cpu:0): flags: 0x0, 1024000 bps, name:
  7(cpu:0): flags: 0x0, 10240000 bps, name:
  8(cpu:0): flags: 0x0, 1024000 bps, name:
Bandwidth Contracts for cpu type 0 has 0 cp contracts
Queued pkts in cpus:
18:64:72:c8:20:16#
Verification : This command can be used to verify if client traffic are being policed or dropped due to bandwidth contract.
Version history
Revision #:
1 of 1
Last update:
‎11-10-2014 11:46 AM
Updated by:
Labels (1)
Contributors
