How to configure Aruba Instant for Internet Failover?
Internet-Failover is a newly added feature in InstantOS 3.2. When enabled, it can trigger to change the uplink if Internet is unreachable.
As of InstantOS 3.2, four types of uplink configuration is available
Ethernert
Wi-Fi
3G/4G
PPPoE
IAP sends out a ICMP request every 30 seconds, and if there are 10 replies lost in total, under current uplink, then IAP will disable current uplink then switch to next uplink.
Product and Software: This article applies to Aruba Instant Access Points (IAP's) running Aruba InstantOS 6.2.0.0-3.2.0.0
Follow images below to configure an Virtual-Controller with "Internet failover":
  1.  Using GUI, login into Virtual Controller.
  2.  Click on "Settings" from Main Menu in the top right corner
  3. On Settings window, click on "Show Advanced Options" at the bottom.
NOTE:
  • Interval between consecutive ICMP request is controlled by the option "Failover detection frequency". The Default value is 30 seconds
  • Number of packets lost before the uplink is considered as down is controlled by the option "Failover detection count". The default value is 10.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 03:15 PM
Updated by:
Labels (1)
Contributors
