Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
View Entry
Controller-less WLANs
Community Home
Discussion
0
Library
924
Members
12
last person joined: one year ago
Articles relating to existing and legacy HPE Aruba Networking products and solutions including IAP, Central / HPE Aruba Networking Central, MSR, and Outdoor Mesh
Back to Library
How to configure External DHCP server for a Network in Instant AP through Aruba Central.
0
Kudos
Jul 17, 2014 12:26 PM
Arunkumar
How it works
When configuring a SSID profile, a VLAN needs to be specified.
The VLAN can either be ‘Virtual controller assigned’ or ‘Network assigned’.
For using the External DHCP server, VLAN has to be configured as Network Assigned.
There are 3 types of VLAN allocation for Network Assigned.
Default – Uplink native VLAN (by default VLAN 1)
Static – Assign a static VLAN, which is part of the uplink
Dynamic – VLAN derived based on VLAN derivation rule configured
Configure a DHCP server or relay agent in the uplink.
IAP cluster acts like a pass through L2 switch in this scenario.
Client gets an IP address from the DHCP server through the uplink.
How to configure
While configuring a SSID profile, in the VLAN tab, choose “Network Assigned” in “Client IP Assignment”.
Under “Client VLAN Assignment”, choose one of the 3 values “Default”, “Static” or “Dynamic”. Discussion how each of these methods work is out of the scope of this topic. So let us take an example of Static VLAN assignment.
Configure the VLAN ID as the VLAN on which the DHCP server is available on the uplink.
Ensure that the uplink switch has the necessary VLANs allowed and trusted. By default all VLANs are allowed on an IAP uplink port.
Complete the remaining configuration of the SSID profile of “Security” and “Access”.
Troubleshooting
To enable debugging for logging in ‘Aruba Central’, goto Configuration -> System -> Logging. Change level to ‘Debug’ for necessary fields.
Ensure that the client is associated to the AP, run the below command in Virtual AP.
This would give client association status along with the VLAN in which it is connected.
The client is correctly connected to VLAN 1.
To check if the authentication was completed for the user, run the below command in the Virual controller. Incase of using any PSK, the 4 way handshake has to complete for the client to ahead and get an IP address.
To verify if a client has authenticated and got an IP address, verify it by means of checking at “Event log”.
To check the user details from the user table along with IP address and MAC address, check in the VC GUI.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
