How to configure Facebook WiFi in IAP?
MVP
MVP
IAP running 4.1.1.3 and above code version.
To use Facebook Wi-Fi:
  1. Connect to the wireless network.
  2. Launch your web browser (ex: Firefox).
  3. Your browser will open automatically to the business’s Facebook Wi-Fi Page.
Step 1: Create SSID on IAP
On UI page, click “New” in “Networks” tab.
Input SSID name, then click “Next” to go to VLAN page.
Step 2: Configure Vlan assignment. Here we are using default settings.
Step 3: In “Security” page, select “Facebook” in “Splash page type”
Step 4: In “Access” page, don’t change anything, click “Finish”.
By now, SSID is created for Facebook WiFi and the IAP will starts register to Facebook automatically. There is a link in “Security” page in SSID, it presents registration is done
The link on “Security” page of SSID to bind Facebook page with VC, it would prompt login with your Facebook account.
wlan ssid-profile myface
enable
index 0
type guest
essid myface
opmode opensystem
max-authentication-failures 0
auth-server InternalServer
rf-band all
captive-portal facebook
dtim-period 1
inactivity-timeout 1000
broadcast-filter none
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
show clients debug
Client List
Name         IP Address   MAC Address        OS     Network  Access Point       Channel  Type  Role         Signal    Speed (mbps)  *Reauth Age  *Reauth Interval  *Reauth ESSID  *Authenticated  DEL  Age  Vlan     *ESSID  *Private role info  Accouting Session Name  Accouting Start time  BSSID              Idle Timeout  csum      *mcast groups                   *Acct Interval  *Class Attribute  *Dhcp-Opt Vlan  *Dhcp-Opt role  Intercept  Offline  *FB Token  *FB RxBytes  *FB TxBytes
LAP-02-1364  192.168.1.4  18:3d:a2:02:47:c4  Win 7  myface   18:64:72:c4:06:2c  64-      AN    External CP  54(good)  270(good)     0            0                                no              no   7    1(SSID)  ()      0(0-0)              LAP-02-1364             1435840306            18:64:72:c0:62:d2  1000          2343201d  (2)239.255.255.250,224.0.0.252  0               null              0,(null)        ,0,0-0          no         no       null       null         null
# show facebook
Facebook Id     :700440080060017
Config Url      :https://www.facebook.com/wifiauth/config?gw_id=700440080060017
Version history
Revision #:
2 of 2
Last update:
‎07-16-2015 04:27 AM
Updated by:
Labels (1)
Contributors
Comments
ignrivas
If only marks the facebook box, and do not set the IAP remains offline and does not allow the connection. And you have to reset it as the only option.
acaboy69
We found a problem with Facebook, login, in an Android device, 1) Not exist the splash page, the user need to open a browser to target a Facebook register page. 2) Can use any Internet service (whatsapp, facebook app, email, etc) without click Register in Facebook page.
ignrivas
the problem, connect to facebook
acaboy69
Me too, my problem it´s with Aruba Instant.
Quedamos atentos para cualquier aclaración o duda .
Oscar Acevedo Ugarte
Director General
ARQUISYSTEMS
Tel: +52 (55) 88517742, ext. 111; Cel: +52 (55) 30172953,
Correo: oscar@arqsys.com Página web: www.arqsys.com
BenDef
I Have the same problem with iap205 and ArubaInstant_Taurus_6.4.4.3-4.2.2.0_53034
With a notebook we have directly a redirect page with facebook authentication but you can open a new tab and if you use https://... you can surf without authentication . If you use http you are directly redirect to facebook authentication page.
With android or ios doesn't work correctly you don't have splash page . Idem of notebook ... if you use https you can surf without authentication .
Do you have a solution ?
Thanks in advance
benyoung
same issues: can surf https without authentication. I try to use the pre-auth role but it does not help.
nidron
Have anyone solved this problem. It was easy to set up the Facebook Wi-Fi according to this instructions. But as previous users I experince that you can use the internet without loging in to facebook, especially when using phones and tablets. I guess there should be a solution to this problem but how?
acaboy69
The situation continue, if you configure Facebook authentication, the end user can use other apps and access internet without push botton LIKE on Facebook Business Page;
The end user only can´t access any web page without authentication
Fred Mancen
I am facing the same issue. Exactly the same way as the other community members.
Hope this fix could be released ASAP.
Netcon147
same issue here.
works fine on windows 7/10
IOS and Android devices can connect without facebook like...
annoying!
Elia Daibes
vs
