How to configure a static channel & power for an IAP?
MVP
MVP
We can configure static channel & power for an IAP using WebUI and CLI
Using WebUI
1. Click on the respective AP
2. Click on Edit
3. Click on Radio
4. Change the Channel and Power for the a-band and g-band respectively
Using CLI
    Syntax
        IAP# a-channel <channel> <power>
        IAP# g-channel <channel< <power>
        IAP# commit apply
        IAP# write memory
    Example
        6c:f3:7f:c4:0b:68# a-channel 161 23
        6c:f3:7f:c4:0b:68# g-channel 11 23
        6c:f3:7f:c4:0b:68# commit  apply
        6c:f3:7f:c4:0b:68# write memory
    6c:f3:7f:c4:0b:68# show ap-env
    Antenna Type:Internal
    wifi0_arm_channel:161
    wifi0_arm_power:23
    wifi1_arm_channel:11
    wifi1_arm_power:23
    disable_prov_ssid:1
    mesh-ldart-disable:1
    6c:f3:7f:c4:0b:68#
    6c:f3:7f:c4:0b:68# show  aps
    2 Access Points
    Name               IP Address      Mode    Spectrum  Clients  Type         Mesh Role  Zone  Serial #   2.4 Channel  2.4 Power (dB)  2.4 Utilization (%)  2.4 Noise Floor (dBm)  5.0 Channel  5.0 Power (dB)  5.0 Utilization (%)  5.0 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id  Config Csum  Ext SSID Active  Age
    6c:f3:7f:c4:0b:68  10.17.170.247*  access  disable   0        135(indoor)  Portal     -     AX0162837  11           21              66(ok)               -87(ok)                161          22              17(good)             -96(good)              No                   none       1          11838        disable          3d:2h:41m:10s
    d8:c7:c8:cc:90:6e  10.17.170.246   access  disable   0        134(indoor)  Portal     -     AX0084024  11           24              36(good)             -96(good)              161          22              8(good)              -96(good)              Yes                  none       1          11838        disable          3d:2h:41m:4s
Version history
Revision #:
2 of 2
Last update:
‎08-05-2016 11:27 AM
Updated by:
Labels (1)
Contributors
Comments
Dapindra
Can u please help to explain the same process mentioned above with IAP version 6.5.2.0-59123?
We have 100 IAP to configure for static power and channel. So we need to be able to copy/paste in the cli.
Regards
Dapindra Singh Gill
